Amp gauge wiring
Craig
10-30-2000 03:10:58
I have a TO-20 that has been coverted to 12 volts. I am trying to hook up a new amp gauge and was wondering if I am doing it right. I have the battery terminal lug from the voltage regulator to one side and the other side going to the hot terminal on my starter switch. Is this correct? I see no movement on the gauge when the tractor is running or when I turn on my lights. Any Ideas?
Thanks!
Biv
10-30-2000 15:23:30
 Re: Amp gauge wiring in reply to Craig, 10-30-2000 03:10:58
I think the TO 30 12 volt diagram
will probably work for you.
