PTO slips?
Mick TX
09-18-2006 08:41:53
I've checked the archives and can't find anything, so I'd appreciate some input. I've got a 51 TO30 with an old Danuser bush hog. Saturday, I was bush-hogging some moderately tall grass and ran out of gas. I put a few gallons in, fired it up, put it in neutral, and engaged the pto to get the blade spinning so as to clear out any grass balled up under the mower deck. When I let out the clutch, the blade didn't spin, but the engine didn't bog down either. I dragged it to a clear spot a few yards away. When I got to the clear spot, I engaged the pto again and it started spinning like it always has. Fluid levels showed to be fine, so I finished mowing about an acre with no other problems. Are there clutches in the pto that allow it to spin or what? I know it can't be good to have the pto engaged and the bush hog not spinning. I'd appreciate any advice on this.
Mick in TX
09-19-2006 07:23:20
 Re: PTO slips? in reply to Mick TX, 09-18-2006 08:41:53
Thanks, everyone, for your replies. So far, so good.
Jeff-oh
09-18-2006 11:36:15
I agree with Steve. Most likely you did not have the PTO Fully engaged. I would not worry.
The PTO on the TO-30 does not have "ground"-PTO. That feature was not available until the TO-35. There is no PTO clutch. So there is nothing to slip. The PTO on a TO-30 is direct driven on the transmission shaft. It is either on or not.
The lever on the side has a short lever on the inside that rides in a grove on the PTO gear. When moved it slides the PTO Gear aft to mesh with a gear on the Engine power shaft going to the transmission.
Most likely the gear lined up tooth to tooth and it the lever felt like it was engaged, or as steve said it was not fully engages and slipped out.
Relax, don"t worry, go mowing. If this becomes a cronic problem then write back on it.
Jim in OH
09-18-2006 09:52:05
'51 TO-30 does not have live PTO/dual stage clutch... This is just a guess,.... but it sounds more like you have two ways to engage the PTO... "ground" and "engine"... Perhaps it was in "ground" when you were not moving... Jim
woodache
09-18-2006 09:36:12
 Your main clutch is Re: PTO slips? in reply to Mick TX, 09-18-2006 08:41:53
Your main pto clutch is worn out. This tractor must have a duplex or live power clutch. You will have to replace it sorry!
steveormary
09-18-2006 11:07:14
 Re: Your main clutch is Re: PTO slips? in reply to woodache, 09-18-2006 09:36:12
MickTX
We had a 52 TO 30. The pto was driven thru the transmission. The pto has to be engaged to operate the 3pt. One thought comes to mind. You may not have had the pto fully engaged and it could have popped out of gear. Has everything been ok otherwise?.
steveormary
