PTO splines
Allan S
09-19-2006 14:38:34
Should grease be applied to the splines of the PTO / implements when coupling? - TED20
Regards,
Allan
George Fager
09-22-2006 02:07:49
 Re: PTO splines in reply to Allan S, 09-19-2006 14:38:34
you could use antisizie on the splines as well this in not a lubicant but a coating to prevent parts from becoming locked together
George
John (UK)
09-20-2006 05:28:38
Grease or oil will collect grit and cause wear to the shaft and coupling, but as Jim rightly says it does help prevent the coupling freezing to the shaft in extreme cold and usually when it is so cold there is little or no grit about anyway. This also applies to the ball ends on the lower and top links of the tractor. So under normal working conditions NO....under extreme cold conditions YES
Jim W
09-19-2006 14:42:59
I do apply it because I use a snowblower, and it helps prevent the shaft from freezing onto the pto.
It will also make it generally easier to couple and decouple - but this is not "official" - just personal view
Jim
