One more ques..TO-35 rear end oil???
770
10-07-2006 06:05:50
1959 TO-35..... I want to change the rear end oil this weekend. What should I use??? Thanks to all replies!
phil(va)
10-08-2006 20:22:38
 Re: One more ques..TO-35 rear end oil??? in reply to 770, 10-07-2006 06:05:50
Takes 8 gallons if you get all the old oil out, which often doesn't happen.
Randyr
10-07-2006 06:50:38
GL-1 80w90 oil is the right stuff. I hear that 15w40 diesel engine oil is ok too.
DennisPinOhio
10-07-2006 12:15:24
 Re: One more ques..TO-35 rear end oil??? in reply to Randyr, 10-07-2006 06:50:38
Be very careful what you buy. 80/90 is the wrong stuff and WILL DAMAGE the parts inside. Be sure you get a true GL-1, 90 weight, straight mineral oil, or you can use a multi-grade engine oil, like he said. I put 20w50 in mine.
Randyr
10-09-2006 09:45:48
 Re: One more ques..TO-35 rear end oil??? in reply to DennisPinOhio, 10-07-2006 12:15:24
Do you mean 80w90 GL1 is wrong and 90 GL1 is right? I thought it was most important for it to be GL1, not GL5.
770
10-07-2006 12:49:07
I bought GL-1 90w from my local Napa.....is this OK?
Glenn/Calif
10-07-2006 16:13:35
 Re: One more ques..TO-35 rear end oil??? in reply to 770, 10-07-2006 12:49:07
Yep,the NAPA GL-1 is the right stuff. Have it in my TO-20. Be careful when filling the rear-end/tranny. The stuff is very thick and slow to settle down. Don't get in a hurry like I did and find you have a gallon too much. It is a bear to suck out the excess. With winter coming on, if you're in the colder areas, you might want to use the 20-50 multigrade for the winter. LOL. Glenn
Dean
10-07-2006 16:13:15
Yes. 90W GL-1 from NAPA or any place is OK.
Dean
