Friction Disk
GENE STEVENS
10-10-2006 04:25:56
What type of material should be used for the friction disk on a TO-20 throttle and on a position control?
Thanks Gene
Griz
10-11-2006 11:58:00
 Re: Friction Disk in reply to GENE STEVENS, 10-10-2006 04:25:56
I tried the cork and radiator hose. Neither worked very well. I tried a mouse pad it works great. Holds on for dear life.
Griz
GENE STEVENS
10-10-2006 20:53:52
Pickedup some and have cut the disk out already. Thanks All Gene
Jeff-oh
10-11-2006 06:05:25
 Re: Friction Disk in reply to GENE STEVENS, 10-10-2006 20:53:52
I got 1/8" cork gasket material at TSC. I used my wife's scrapbook hobies, circle cutter to cut a perfect disk... I knew her hobbie would be good for something someday.
PS the cutter also works great for TO-20 oil pan gaskets and transmission inspection plate gaskets....
Jeff
Jerry/MT
10-10-2006 14:21:56
Gene, Walt's tractors has them for a $1 apiece and they are made out of cork. I got some and finally (after 10 years of messing around with a loose control lever )my TO-30 hitch control works like it's supposed to. I tried other materials but the cork disc work right. If you can find some thick cork sheets(1/8" or 3/16") you can make your own.
Jeff-oh
10-10-2006 05:36:57
I used 1/8" cork gasket material.
