Bell Housing
Tim Figgins
11-18-2000 13:08:00
I have a TEA20, underneath the bell housing there is some sort of small drain hole, almost like a sump hole. My problem is that I have gearbox oil slowly dripping out of here. Does anyone know if there is a seal somewhere that needs replacing. Cheers Tim
Big Fork
11-28-2000 19:41:23
 Re: Bell Housing in reply to Tim Figgins, 11-18-2000 13:08:00
It could be a rear engine seal too. If you break the tractor I would change it also and take a good look at the clutch while you are in there.
Bob Akin
11-20-2000 22:17:41
Tim,
There is a seal for the input shaft of the transmission that needs to be changed, Unfortunately the engine needs to be removed to do the job. Once the engine is removed, the seal is fairly easy to get to. Good luck.
