TO-30 refurb
mvguy
10-31-2006 06:06:23
I recently obtained a "53 TO-30 that is in decent condition. However, it does need some reapairs to make it suitable for work use as the ferg has been sitting for quite a while now. The obvious items are brakes, some gaskets, and a right rear axle seal that has been leaking for some time. Now to the point of my message. Where should I start to look for problems other than the obivous already stated? It starts and runs (most of the time at least).
That"s about all I can think to tell you about the condition of said tractor. This is my first attempt at taking a machine in this poor of shape and getting it operational again.
Thanks in advance, sorry for the rambling
Mike
Jerry/MT
10-31-2006 16:54:20
 Re: TO-30 refurb in reply to mvguy, 10-31-2006 06:06:23
One of the major problem areas is the fuel tank. A lot of these tractors were parked in the North 40 and left to the elements. The tank gets dirt in it and condensation causes a lot of rust, which then finds it's way into the tank valve, screens/filters, and some of the fine stuff makes it to the carb and causes problems. Make sure that your tank is in good condition and clean it out very thoroughly. I put a lawn mower fuel flter in my uel line to take care of the fines stuff I can't seem to get out. I have a broken baffle in my tank and it seem to keep things stirred up.
Check out your distributor to make sure the bushing/shaft aren't worn. make sure all the primary ignition system wiring is in good shape and the connections are clean and tight. Your spark plug wires should have copper conductors and the insulation should not be cracked or frayed. The distributor cap terminals and sockets should be free corrosion and the cap should not have any cracks.
If the trans/hydraulic oil is dirty or creamy colored (due to water) change i. There is a excellent description on how to do this by Jeff(OH) in the archives so do a search and find it. It takes 6 gallons of GL-1 type oil that is available at NAPA and elsewhere. Your oil seal leak may be a result of water in the trans/hydraulic system causing the fluid level to be too high
Clean the airfilter element out. Ytey are usually crudded up. Clean the oil cup and add clean oil.
Change out the engine oil and add a good detergent motor oil and replace the filter. A spin on filter adapter and filter is available to replace the original but there is no problem finding the OEM filters. Flush and drain the cooling system and fill with 50/50 ethylene glycol anti freeze.(The radiators in these old beasts are often in sorry shape due to the use of hard water for the coolant, leaving lime deposits in the rad cooling passages and the engine water jacket.)
Pull the plugs and "read" their condition. Give it a tune up (plugs points and condensor) and put 'er to work. If you pull the tank to clen it, you may want to check the valve lash while youhave the tank off.
Finnal, invest in a factory shop manual, a parts manual and an owners manual. They are usuually reprints but they have a wealth of info found no where else. In my opinion the IT manuals, while useful, are not as good as the factory manuals unless you are an expert on these old machines.
hope this helps you.
