Hard-starting TE-20
Tex Ferguson
11-24-2000 18:29:52
My '49 starts great when pulled for about ten feet, and then runs great. But the old beast refuses to pop when I use the starter. New battery, full charge, ignition system in fair shape(Delco distributor/negative ground). I get fairly good spinspeed from the starter, but not a single pop! What am I chasing? Short in the starter? Thanks for any advice!
Big Fork
11-28-2000 19:34:22
 Re: hard-starting TE-20 in reply to Tex Ferguson, 11-24-2000 18:29:52
Has your tractor been coverted to 12 volt? If it hasn't you might have the negetive post grounded on your battery....
Bob Akin
11-27-2000 17:27:13
It could be a weak coil. Because there is a significant voltage drop when starting, the coil may not be able to make a spark across the plugs when the volts are low. Try either another coil or power the coil from a separate battery just to try it out.
