TO20 Year
bobsinmd
11-12-2006 14:24:54
I have a Ferguson TO20 with a serial number of 110566. What year is it?
It has Z120 stamped on the engine block, and TO
stamped all over the rest of it.
Also,what model Ford has the same "Ferguson System"?
Any help would be greatly appreciated.
Thank You
Bob
Jeff-oh
11-13-2006 06:13:30
 Re: TO20 Year in reply to bobsinmd, 11-12-2006 14:24:54
Bob,
If the SN is correct on the data plate (i.e TO 110566) then you have a 1953 TO-30. As you say the engine is a Z120, then the engine may have been replaced in the last 53 years.
Jeff
Irv (Ia)
11-13-2006 03:15:28
Bob, Ya sure ya got the right amount of numbers? Look under serial numbers under Research and Info to the left on this sight, and check your numbers again. The serial number plate is above the steering wheel.
Irv
