Hydraulic gaskets
Steve,NC.
11-26-2006 06:45:20
I just got thru instaling kits in the valve chambers for my hydraulic pump.Do I use gasket sealer when I remount them or not,if so what kind.
John (UK)
11-26-2006 11:56:37
 Re: Hydraulic gaskets in reply to Steve,NC., 11-26-2006 06:45:20
NO gasket cement on the side chamber gaskets. You can use a little cement on the front right corner of the Pump where the pressure comes up. Tighten the setscrews either side of the pressure point first and then tighten the rest sequentially to a torque of 55 - 60lbs ft. The setscrews holding the caps to the side chambers are the same torque. Do make sure that you use the correct oil in the Hydraulic System use either GL1 90W or 15W/30 Multigrade, 6 US galls from totally empty at the THREE drain plugs.
