Ford Loader on TO-20
Dan Oehmke
12-02-2006 17:59:26
I am trying to add a side step Ford 190-118 Loader to my TO-20. From what I can tell in previous posts, what works for an 8N, should bolt right-up on a TO-20. Unfortunately, I have the front suspension plate for a Ford NAA or 800, which won't work. So am looking for a "Suspension, Front (Welded Assembly), part no. 195878.
Though I'd also need the Axle pin, for shaft to pass through to the pump, but --- it looks like the Ford pin is not interchangeable on the TO-20. Can anyone help me to know what kind of axle pin and/or part number I'm looking for? And any ideas where to find a suspension plate and axle pin?
Thanks!
Irv ( Ia)
12-03-2006 07:16:53
 Re: Ford Loader on TO-20 in reply to Dan Oehmke, 12-02-2006 17:59:26
They have an axle pin on this site with a 1" hole in it for a crank. I would think that would be big enough for your pump drive shaft. Look at tractor parts under "marketplace" at the upper left hand corner of this page.
Irv
HowieNJ
12-03-2006 04:48:35
i believe the 8n axle pin is the same for your fergy cant help you with loader frame
