Serial Number Location
Nickademus
12-23-2006 18:06:04
Can someone tell me where to locate a serial number. Seller is listing tractor as a MF TO 35 Diesel Deluxe. It is a standard 4 cycl. diesel. Seller doesn't know were it is.
Nickademus
12-25-2006 12:06:47
 Re: Serial Number Location in reply to Nickademus, 12-23-2006 18:06:04
Owner said he couldn't find seriel number on tank, but engine seriel number is 3J67818E.
Can that get me into the year the tractor was made?
John (UK)
12-24-2006 08:02:34
Should be on a plate on the dash panel. If the plate has been removed you may see the 4 rivet holes. Sometimes the number was also stamped in the rear gutter on the fuel tank. The engine number is stamped into the cylinder block just above the generator.
Nickademus
12-25-2006 08:13:57
 Re: Serial Number Location in reply to John (UK), 12-24-2006 08:02:34
John
Thanks, the seller is saying that the metel plate on the dash only holds starting instructions. I'll have him check the other locations you mentioned. Merry Christmas
Nickademus
John (UK)
12-26-2006 05:52:10
 Re: Serial Number Location in reply to Nickademus, 12-25-2006 08:13:57
There should be a plate with the starting instructions but the main plate with the serial number should also be there. A lot of people remove these plates so they can claim the tractor to be younger than it actually is.
nickademus
12-26-2006 15:09:19
 Re: Serial Number Location in reply to John (UK), 12-26-2006 05:52:10
John
Thanks for the information.
I have notified the owner that I was not going through with the purchase.
Nick
John (UK)
12-26-2006 16:14:09
 Re: Serial Number Location in reply to nickademus, 12-26-2006 15:09:19
That could be a VERY wise move on your part...
Good Luck I hope that you soon find a Genuine one.
Seasons Greetings to You and Yours....John
