overbore question
overunder1
12-24-2006 08:58:50
Interesting threads on rebuilding the last couple of days. If one is going to tear a Z129 down and freshen it up just how large an overbore kit can one install? Z129/Z134/ larger? without having to seriously modify the block. It would seem that there may be a few extra horepower available going this route. -Lee
1954 TO30
Dan S (NY)
12-27-2006 09:23:52
 Re: overbore question in reply to overunder1, 12-24-2006 08:58:50
Engine Bore Stroke Displacement Z120 Original 3 3/16 (3.1875) 3 3/4 (3.75) 119.7ci Overbore Kit 3 5/16 (3.3125) 3 3/4 (3.75) 129.27ci
Z129 Original 3 1/4 (3.25) 3 7/8 (3.875) 128.58ci
Overbore Kit 3 3/8 (3.375) 3 7/8 (3.875) 138.67ci
Z134 Original 3 5/16 (3.3125) 3 7/8 (3.875) 133.58ci
Z145 Original 3 3/8 (3.375) 4 1/16 (4.062) 145.36ci
Dan S (NY)
12-27-2006 09:25:46
 Re: overbore question in reply to Dan S (NY), 12-27-2006 09:23:52
Well, the formating on the chart didn't take...oh well.
ron tepoel
12-24-2006 20:32:33
big bore kits are/were available.
Crank stroke is not interchangeable easy.
extra bore can be a had with dodge or other pistons
bigger valves a big plus for to-20
Sam from WA
12-24-2006 17:29:48
Some of the displacement is length of stroke. depending on how large you want the bore, you may not gain a whole lot. if you change bore size, most times, you have to get new pistons and all.
Gerald J.
12-24-2006 10:58:09
Part of the larger displacement is a longer stroke for the Z-145. A 1998 CT catalog only shows increased bore kits for TO 20 and TO 30 with Continental engines. For TO20 increases bore from 3-3/16" to 3-5/16". Claims up to 4.2 hp gain. Increases displacement 7.9%. For TO-30 increases bore from 3-1/4" to 3-3/8" which increases displacement 7.8%. 7.8% of 30 hp is 2.4 hp at best unless the pistons also increase the compression ratio, there's not that much help for crankshaft torque beyond just fixing a leaky old engine.
Gerald J.
