23C torque
John in Ca
12-29-2006 18:49:59
Can anyone tell me at what RPM a 23C will make its max amount of torque ?
John (UK)
01-01-2007 12:09:56
 Re: 23C torque in reply to John in Ca, 12-29-2006 18:49:59
The 23c engine max torque was at 1600engine rpm.
Max brake hp was 37.25
Max brake hp on a Perkins 3A-152 was 37
gerard
12-30-2006 12:39:06
I"ve always considered it to be negligible throughout the range - probably peaking when the starter motor"s running.
Jack in NB
12-30-2006 17:03:26
 Re: 23C torque in reply to gerard, 12-30-2006 12:39:06
Actually I found my 23C to be a smooth, powerful, long lasting engine. Not quite as much power as the later Perkins, but near enough.
Ours had probably 5000 hours on it at first overhaul, and the crank was still standard size.
The problem was starting, and an electric block heater did a great job correcting that. Used it even on the hottest summer days!
On the original question of tourque, I've never seen performance curves for the 23C, but most engines are designed for max tourque around PTO speed - about 1500 RPM.
