TE 20 85 or TE 30
Andy Moncman
01-08-2007 07:49:47
I just purchased this tractor at auction,
serial no. is TEA 273798. I need a rotor,
not sure which kit to purchase since the previous owner replaced points with something other than original
parts. Is there a difference between the two kits,
s 42773 and s 42772.
John (UK)
01-08-2007 18:06:23
 Re: TE 20 85 or TE 30 in reply to Andy Moncman, 01-08-2007 07:49:47
There are two different sets, the difference is in the contact set. One set was fitted to most tractors but the other set came in when they were going to change to the 35 series. There is a number on the side of the distributor on an oval plate that is held to the distributor bowl with two rivets. If you give me the number on the plate I may be able to work ot what the contact set should be. Alternatively have you thought about converting to electronic ignition, that would do away with the points for ever. Pertronix do a system for the tractor. If the distributor is original the number of the points should be Sparex S42372 or lucas 407050 the later set came in about 1955
Andy Moncman
01-08-2007 19:10:07
 Re: TE 20 85 or TE 30 in reply to John (UK), 01-08-2007 18:06:23
JOhn,
I found a rotor at local part store that matched up.
Thanks
howieNJ
01-08-2007 16:55:39
i don't have a parts book but it may mean 6 or 12 volt? 12 volt electrics phased in from serial# 250001
Andy Moncman
01-08-2007 19:15:18
 Re: TE 20 85 or TE 30 in reply to howieNJ, 01-08-2007 16:55:39
Howie,
I found a rotor that matchedd up at a local parts store.
Thanks
