TO30 clutch question
antiquejohndeere
01-08-2007 08:02:03
I am having to replace my clutch lining due to a transmission main shaft seal leak that soaked my clutch. I had the pressure plate and flywheel surfaced while I had it apart. My question is that when I put it back together my manual says to adjust the 3 release levers until they are 1 3/16" away from the flywheel. Is this measurement correct if everything has been resurfaced? How is the best way to gauge this if you don"t have the tool that the service techs had in their shop?
John (UK)
01-08-2007 18:10:11
 Re: TO30 clutch question in reply to antiquejohndeere, 01-08-2007 08:02:03
Build it up on the flywheel and set it then, just as if it was in working position.
