tea 20 lift rocker bushing
Andy Moncman
01-15-2007 17:14:47
Looking for lift rocker bushing. Sparex doesn't show one in their catalog. Thinking might try using drill
bushing, need specs. on I.D., O.D. & length.
Jerry/MT
01-16-2007 21:21:29
 Re: tea 20 lift rocker bushing in reply to Andy Moncman, 01-15-2007 17:14:47
I see what you're looking for now! I was sure tht you were looking for a rockshaft bushing! Glad you found someone to make it.
John (UK)
01-16-2007 07:26:41
Try to find a Triumph sports car club, they will possibly know where to get them as the engine is very similar.. Check that the oil is coming up from the camshaft to feed the Rockers or you will still be in trouble. If the oil pressure is low it could be the Oil Pump needs a new Rotor Pack or the Rear Camshaft bearing in the block is worn.
Andy Moncman
01-16-2007 14:12:33
 Re: tea 20 lift rocker bushing in reply to John (UK), 01-16-2007 07:26:41
The bushing I am looking for is part of
the three point hitch near the top link,
according to the manual I have it is called the
"lift rocker". the bushng goes through the center lug on the center housing. I have it out , it mics 1.000" O.D. X .755" I.D. and 2.800" Long, not sure of the
material. My buddies at a die shop are going to turn
one up for me. Thank for the input.
John (UK)
01-16-2007 14:29:31
 Re: tea 20 lift rocker bushing in reply to Andy Moncman, 01-16-2007 14:12:33
It is called the lift shaft and the bushes are available from Sparex as part S41425 and you need 4 per tractor according to their list. dimensions are 2" x 2-3/8" x 1- 3/8"
Andy Moncman
01-16-2007 19:08:29
 Re: tea 20 lift rocker bushing in reply to John (UK), 01-16-2007 14:29:31
John,
Posted a photo of the lift rocker and bushing
in the Parts & Pieces section. Like I said the O.D. is 1.000" the I.D. is .755" and the
length is 2.800".
Jerry/MT
01-16-2007 13:41:53
I thought he was talking about the rock shaft bushing, John.
John (UK)
01-16-2007 14:14:12
 Re: tea 20 lift rocker bushing in reply to Jerry/MT, 01-16-2007 13:41:53
Hahaha reading too quick Jerry, I do that too, gets me in trouble as well....John
Jerry/MT
01-15-2007 20:29:31
Try Walts Tractor Parts. I got some from there.
