front wheel weights
Overunder1
01-20-2007 10:19:11
What are the correct weights to use for the (original) front wheels and is there a source to purchase them without buying the truck used to deliver them?
-Lee
oldgit
01-20-2007 18:22:33
 Re: front wheel weights in reply to Overunder1, 01-20-2007 10:19:11
Were there rear wheel weights made for these tractors?
MF Poor
01-22-2007 11:06:39
 Re: front wheel weights in reply to oldgit, 01-20-2007 18:22:33
Most certainly was! Both front and rear weights. Fronts went on the inside of the rims. Rears used a "base weight" to fasten directly to the wheel center dish. Then additional weights attached to the base weight. I've got 2 pairs of base weights. They came with all the mounting hardware. (2 pairs I have are specifically for 28" spin-outs) and 4 pairs of add-on weights. Never been bolted to a tractor either. Good as new and just as heavy as the day they were made!
Jerry/MT
01-20-2007 13:24:19
I've been looking for a set myself but they all seem to be located in the Mid-West or the East and they cost more to ship than to buy. I'm considering putting -20F windshield washer fluid in my front tires for ballast.
Ron Kanouse
01-21-2007 05:11:09
 Re: front wheel weights in reply to Jerry/MT, 01-20-2007 13:24:19
I have a set for sale
Jerry/MT
01-21-2007 19:55:22
 Re: front wheel weights in reply to Ron Kanouse, 01-21-2007 05:11:09
Where are you located?
Ron Kanouse
01-22-2007 04:00:58
 Re: front wheel weights in reply to Jerry/MT, 01-21-2007 19:55:22
South Webster, Ohio
Jerry/MT
01-22-2007 21:06:28
 Re: front wheel weights in reply to Ron Kanouse, 01-22-2007 04:00:58
Ron, I live near St. Ignatius, MT. that's probably about 1800 miles from you. What do you want for the weights?
Ron Kanouse
01-23-2007 10:25:52
 Re: front wheel weights in reply to Jerry/MT, 01-22-2007 21:06:28
100.00
overunder1
01-20-2007 13:02:45
yes Dean, that is what I am looking for. I am hoping someone can provide a sparex or agco part number so I can get them ordered through a local dealer.
-Lee
Dean
01-20-2007 11:28:05
OU:
If you are speaking of front weights for a vintage Ferfuson or MF with 16" front wheels, these tractors used two-piece weights bolted to the inside of the front rims very similar to those used by Ford at that time.
I have a set of original MF weights (not for sale) and also know the whereabouts of another set that is for sale. These are in IN and unless you are close by the shipping will be expensive as they weigh about 100 lbs./side.
Dean
