T0-30 Electrical Question
Bill Mo
01-23-2007 07:23:40
I recently acquired a T0-30. It had been converted to a 12 volt alternator system. The gear shift switch had been bypassed and replaced with a regular switch. Everything worked fine until I replaced the alternator and battery yesterday because they were both in bad shape. After they were replaced the tractor started fine, ran fine, and charged normally. BUT when the switch is turned off the tractor just keeps running normally. The switch won't turn it off. I can't find anything that I hooked up wrong so far. Any ideas? Thanks.
RJW
01-23-2007 20:22:08
 Re: T0-30 Electrical Question in reply to Bill Mo, 01-23-2007 07:23:40
I believe it takes a 50 volt/1 amp diode. Radio Shack has them for a couple bucks for two. Solder one in the line and put some heat shrink over it.
Bill Mo
01-25-2007 05:54:05
 Re: T0-30 Electrical Question in reply to RJW, 01-23-2007 20:22:08
Thanks for the suggestions. I"ll give it a try and let you know how it works out!
RandyR
01-23-2007 10:04:57
Is there a diode on the excitation line? There should be, otherwise the engine will keep running when you try to shut it down.
Try this:
http://www.ytmag.com/cgi-bin/viewit.cgi?bd=ferg&th=46761
Bill Mo
02-21-2007 09:07:25
 Re: T0-30 Electrical Question in reply to RandyR, 01-23-2007 10:04:57
Adding the diode solved the problem. The switch now works correctly again. Thank you!
