TO30 lift goes up by itself and won't go down
Anthony Fowler
01-23-2007 17:56:15
I just bought a '54 TO30, when I went to look at it, the lift worked alright with a bush hog on it. When I got it home I was taking the bush hog off. I already had the top link off and decided I didn't want to put it in that spot, but the lift wouldn't lift the bush hog back up. I lifted the back of the bush hog up and reattached the top link and the lift worked again. After un hooking the bush hog the lift then went up by itself and wouldn't go back down. The lift goes down eventually after stopping the engine, but it only goes part of the way down. Any ideas what this could be? Thanks, Anthony
Jeff in WI
01-24-2007 19:37:50
 Re: TO30 lift goes up by itself and won't go down in reply to Anthony Fowler, 01-23-2007 17:56:15
I have had that problem while plowing snow. Both my cylinder on the front for the blade and the 3 point hitch will not go down unless the clutch is in or the power takeoff is off. It was working fine and then this happened. Any ideas???
John (UK)
01-24-2007 07:51:05
The big Control Spring behind the seat, has it got a lot of end play in it, you should just be able to turn it when the hydraulics are lifted with an implement on it. It needs to be adjusted correctly.
Anthony Fowler
01-24-2007 15:15:37
 Re: TO30 lift goes up by itself and won't go down in reply to John (UK), 01-24-2007 07:51:05
Thanks John. Maybe I'll have time tomorrow before dark to check the Control Spring. How do you go about adjusting it??
John (UK)
01-24-2007 16:06:17
 Re: TO30 lift goes up by itself and won't go down in reply to Anthony Fowler, 01-24-2007 15:15:37
you need to remove the pin through the Yoke end on the rod through the Spring and turn it to tighten it, it may be very tight ot seized and you would have to heat it up, don't force it or you could twist the Control Fork. If you need more info, email me at: fergusontractors(at)tiscali.co.uk
tell me what you find and I can send you what you need.....John
Anthony Fowler
01-24-2007 16:11:50
 Re: TO30 lift goes up by itself and won't go down in reply to John (UK), 01-24-2007 16:06:17
John, I'll try this and see if it works. If not, I'll email you. Thanks for your help, Anthony
Jerry/MT
01-23-2007 21:25:16
I need more information. What was the position of the control lever "...when the lift went up by itself and wouldn't go back down"?
Anthony Fowler
01-24-2007 03:59:58
 Re: TO30 lift goes up by itself and won't go down in reply to Jerry/MT, 01-23-2007 21:25:16
Jerry, the lever was still in the down position when it went back up.
Jerry/MT
01-24-2007 10:07:29
 Re: TO30 lift goes up by itself and won't go down in reply to Anthony Fowler, 01-24-2007 03:59:58
As John(UK) says check the control spring and if that is ok you may have to adjust the control lever. You'll need a manual r maybe ask John (UK) and he can talk you through the method.
