andy...here are some measurements i took this morning that might help you: 1.around front of dogleg along grill...with tape hooked in sheet metal at the bottom of the dogleg, around lower curve and up to where front of dogleg meets hood= 24" 2.from edge of grill, horizontally along top edge of dogleg to rear of dogleg where it meets hood= 15" 3.from edge of grill horizontally to bottom rear edge of dogleg= 16-3/4" 4.from bottom edge of sheet metal directly below bolt hole*, straight up to top edge of dogleg= 26-1/2". center of bolt hole is about 4" from bottom edge of dogleg at this measurement site. 5.width of dogleg at bolt hole* from edge of grill= 5-1/2" 6.width of dogleg across underside of light bracket from edge of grill= 9" * bolt that attaches hood asembly to tractor i hope this get you started. i'll try and get a pic to you later unless someone else posts one for you. these measurements from my to-20 are as close as i can get but may not be exact. i took measurements with a flexible tape around all the curves. i still haven't determined if the to-20 and tea-20's doglegs are the same...i'm just assuming they are. what kind of shape is your fan shroud in? mine was missing when i bought it and i'm still working on making one for it. i made a temporary one for it because of an overheating problem. the temp one i made solved it but i think the right shroud would make it even better. -mike
