TEA 20 gearbox problem
Neil Benton
12-19-2000 22:06:51
My tea 20 has been sitting for 2 months, and has now locked in first gear. I jump started it and ran it for several hours, hoping it would free itself but to no avail. Any suggestions please?
neil benton
12-28-2000 22:34:43
 Re: TEA 20 gearbox problem in reply to Neil Benton, 12-19-2000 22:06:51
Rod, thanks for advice. It worked. Tractor was in remote area. OK now. Thanks again mate.
rod
12-20-2000 03:53:58
A prettty common problem try removing the filler plug by the shifter get a long screwdriver and try to pry the shifter rails back this should get it out of first. You might have to rock the tractor to get strain off gears. If it is not that the fork could be broken off or cracked and bent in that case it is time to take off top cover and have a look inside. regards
rod
