throttle linkage pictures 1952 TO-30
Bob in AZ
02-04-2007 19:19:14
Could someone e-mail me pictures or a drawing of the throttle linkage setup , including how the springs hook up to the carb and governor lever . I just bought the tractor and the previous owner(s) have buggered around with it . I dont know if they changed the springs or not , or if they are even hooked up right . It doesnt seem to run like it should and down on power . I played around with it but I"m kind of shooting blind until my workshop manuals arrive .
My e-mail addy is btadlock@frontiernet.net .
I would sure appreciate it . Thanks , Bob
tuck
02-05-2007 20:40:18
 Re: throttle linkage pictures 1952 TO-30 in reply to Bob in AZ , 02-04-2007 19:19:14
Mike Could you email me the used parts sources too? I need hood latch and guide and grill for To 30. thanks much
tuck
Mike Mohrhauser
02-06-2007 05:21:38
 Re: throttle linkage pictures 1952 TO-30 in reply to tuck, 02-05-2007 20:40:18
Tuck,
Send me an email note and I will try to CC the same info to you that I sent to Bob.
Mike
Mike Mohrhauser
02-04-2007 20:18:53
Bob,
I'll email a picture of my parts manual. I hope it helps.
Mike M.
Bob in AZ
02-04-2007 22:04:35
 Re: throttle linkage pictures 1952 TO-30 in reply to Mike Mohrhauser, 02-04-2007 20:18:53
Thanks Mike , it sure does help a LOT . If that is indeed a TO-30 linkage pic , theres a lot of stuff missing off of mine . The guy has it rigged with a throttle return spring on the butterfly working against a very heavy governor lever spring . I suppose the original linkage just wore out and he did the best he could to make it work with what he had . It actually does work sort of .... but the throttle lever doesnt hold position . I see why now , that friction disc assy is missing .
I need to use the tractor the next few days to move some dirt , then I'll see if I can sort it out and find parts .
I wonder what the chances of getting original parts would be ? Probably slim huh ?
Thanks again Mike .
Mike Mohrhauser
02-05-2007 05:41:49
 Re: throttle linkage pictures 1952 TO-30 in reply to Bob in AZ , 02-04-2007 22:04:35
Bob,
I am going to email a couple sources that have used parts for Fergusons as well as new parts.They frown on it when you post other suppliers with their phone numbers on this forum.
Also from time to time you can find parts listed on eBay.
Mike M.
