ferguson 3 point disc harrow
alan king
02-08-2007 05:39:38
I came across a 3 point drag disc made by ferguson. I thot when i bought it it was a regular drag disc and someone had put a 3 point on it but its factory that way. never saw one before. You cant pick the disc off the ground but just some of the weight off the front I supose for turning on the ends. Anyone know anything about these disc. Anyone want one cause I cant use it without changing it around.
mn.Chuck
02-09-2007 11:56:04
 Re: ferguson 3 point disc harrow in reply to alan king, 02-08-2007 05:39:38
Hi Alan, This disc is a factory disk.There were lots of them in Mn. The disk is a pull type,and
when you raise and lower the three point you also
angle and straighten the blade angle for turning.
Chuck
CENTAUR
02-08-2007 09:04:27
I think you have a early 6 or 7 foot (ferguson) tandem disc which was a pull type pulled by the bottom links and the angle ajusted by the top two links removed at the bottom and brought together in the form of a (V)to do its ajusting A detailed dicription is found on pages 87,88 & 89 in the FORD TRACTOR IMPLEMENTS book by CHESTER PETERSON&ROD BEEMER.128 page good quality paper.CENTAUR
Leroy
02-08-2007 14:05:28
 Re: ferguson 3 point disc harrow in reply to CENTAUR, 02-08-2007 09:04:27
One of these disks would not make the front end of tractor light to want to try to raise off the ground when trying to lift the disc as he is saying
Leroy
02-08-2007 06:51:02
If it will not lift but lifts the front end off the ground there is something wrong, those discs were made with up to 7 blades on a side for total 28 blades on a tandem and any TE-TO 20, TO30, TO35, F35, F40 would handle them, if it is too heavy then figure out where someone has added extra weight because what you are saying is not normal. Now if it was a massey Ferguson they were made in up to a 10' model and that would be too much in both width and weight for the above tractors. If i was going to have a 3 point disc it would be a Ferguson just because of the way they were made and they are a lot better than any of the 3 point disks being made today.
Boss Hog
02-08-2007 05:52:03
There are probably 100 people here who would love to have it, including me.
Can you give us your location and what ya want for it?
alan king
02-08-2007 14:36:26
 Re: ferguson 3 point disc harrow in reply to Boss Hog, 02-08-2007 05:52:03
I live at about 10 miles north of I-40 in arkansas north of the little town of carlisle. The disc has all the grease certs and you can tell it hasnt been used alot. one outside blade is missing and one side that was sitting in the dirt the blades have some deteriation. I gave 110 dollors for it and thats what i would take. I hate to redo it for a drawbar drag disc. I tried to eplain that it isnt a true 3 pt lift type disc but it is a factory 3 pt hitch but it is still the drag type disc.
Boss Hog
02-09-2007 06:17:26
 Re: ferguson 3 point disc harrow in reply to alan king, 02-08-2007 14:36:26
I don't know what you mean when you say: "I tried to eplain that it isnt a true 3 pt lift type disc but it is a factory 3 pt hitch but it is still the drag type disc. "
Here's a pic I took of a Ferguson ABO-22 Disc. Is this what yours looks like?
third party image
Irv (Ia)
02-08-2007 13:08:27
You're right about that!
