Continental vs Standard engines in te20
Lloyd
12-28-2000 09:19:02
How do you tell the difference between the continental and standard engines in the TE20s?
Joe in NY
01-06-2001 14:41:55
 Re: Continental vs Standard engines in te20 in reply to Lloyd, 12-28-2000 09:19:02
If you can't make out the TEA designation on the serial # plate you can tell by the oil filter.
On TEA stanard engines the oil filter is on the left side mounted externaly. TE's with contientals have an internal filter like Ford N"s.
Biv
12-28-2000 19:04:48
One clue is the Continental engine is the Z 120 this number should be stamped on the block. If your serial number is preceeded by the letters TEA you have the Standard engine.
