3 point info
bickletonbob
02-24-2007 08:31:26
The 3 point has all the usual parts, but I do not have a clue what they are all called. Is there a diagram on line that points them out? At the bottom of the fender mount I've got a bracket that I think we used for a mount for a stabliser, a bar that pinned there and down to the draw bar one on each side to prevent the lift arms from swinging back and forth. This was on an old Ford but I think there is little difference. I've looked at a couple older tractors in the area,same basic mount variety of uses.What is it called?
bickletonbob
02-24-2007 22:38:48
 Re: 3 point info in reply to bickletonbob, 02-24-2007 08:31:26
OK, I guess I remember better than I knew. So, when looking at other tractors I saw that some had a single pin mount, some have a double. Any reason for this? Maybe for different implements? Or just a difference in manufacturers idea of the way it should be done? Appreciate the feed back, lots of knowledge out there.
Jerry/MT
02-24-2007 20:55:00
You nailed it Bob. It's a stabilizer bar bracket. There are usually two, one under each fender with a pin.
