MF35
ANTONY
12-31-2000 05:30:19
I HAVE RESENTLY COME ACROSS A RED & GRAY MF35 BUT THE PLATE SAYS IT IS A FE35 SERIAL NUMBER SDF 165389 WITH A 4 CYLINDER STANDARD 23C DIESEL ENGINE. I THORT FE35s WERE GRAY & GOLD.PLEASE COULD ANY BODY HELP ME WITH ANY INFO
Larry
01-05-2001 03:01:19
 Re: MF35 in reply to ANTONY, 12-31-2000 05:30:19
See if this site helps any.
Jim Nisbet
01-02-2001 12:57:53
From 31st. August 1959 Fe 35`s were turned out in Red / Grey with ? Massey Ferguson Decals and T/T front badges ( some were still seen after this date with Red / Grey and Ferguson decals ). After # 166596 the Perkins 3.152 engine was used. The 35X was introduced in 1962 using the A3.152 engine.
Bob Akin
01-02-2001 11:16:10
I believe that you do have an FE-35 built in Coventry England in 1959. I also thought that the FE-35s were grey and gold. Are you sure that the paint is original?
twopop
01-01-2001 09:14:54
it has to be an fe35 since the mf35 did not come with the 23c engine,the to35 used the 23c but the mf35 used the perkins diesel
ANTONY
01-01-2001 11:07:52
 Re: Re: MF35 in reply to twopop, 01-01-2001 09:14:54
IT IS A 4 CYLINDER DIESEL SO BY MY BOOKS ITIS A STANARD 23C BUT THE BONET DECLES SAY MF35 SO SHOULD IT BE RED & GRAY OR GRAY & GOLD
JIM Nisbet
01-02-2001 02:47:07
 Re: Re: Re: MF35 in reply to ANTONY, 01-01-2001 11:07:52
Red and grey Massey Fergusons did exist with the 23 C engine untill the Perkins was avalliable with the purchase of Perkins by M.F. and also buying out the Banner lane plant from Standard.
twopop
01-01-2001 19:32:31
the mf35 would be red and grey i dont know what color the fe35 should be
Dudley Rupert
01-06-2001 23:59:13
 Re: Re: Re: Re: MF35 in reply to twopop, 01-01-2001 19:32:31
May I could follow up/expand a bit on this thread re: TO35 colors -
I acquired a TO35 last summer, S/N 160020, and have it all sandblasted and am now ready to paint it. Under the grey paint on the cast parts I've found green paint so I gather the tractor was originally green. My question is does anyone know what the correct green color is?
And I quess equally important would anyone choose to repainta TO35 green cast and grey tin or would the preferred color be grey cast and red tin?
