TE/TO 20 Continental engine.
Bill Brox
04-14-2007 00:51:50
Hello all.
From time to time here on the forum we all see that some people ask questions about the Continental engine, cracked between cyl. 2 and 3 if I can remember correctly.
I wonder, does this count only for the Continental engine used in the TO 20, or does it count for the TE 20 as well ? And, what is the reason for the cracking, is it just cracking from old age and a lot of use, or is ice and frost giving a helping hand here ?
Bill
ZANE
04-15-2007 15:41:34
 Re: TE/TO 20 Continental engine. in reply to Bill Brox, 04-14-2007 00:51:50
If the engine block is cracked between the two and three cylinders at the bottom it is from freezing.
I have one that I bought because all the wisdom around here said it was not repairable. I bought it in 1964. I took the lead out of 22 bullets and drove the lead into the cracks with a blunt punch. I put new seals in the sleeves and new pistons, sleeeves and rings and when I got it together I put a can of Bar's stop leak in it. I have not had a minutes trouble out of it since.
Zane
Jerry/MT
04-14-2007 20:02:00
Bill, the Continental Z120 is used on the TO-20 and the TE-20 is the same engine. They don't do well if they are overheated and frequently crack between the cylinders near the top of the block.
steveormary
04-14-2007 16:27:03
Bill;
We run 2 Fergusons from 1948 untill 2002. Both were bought new.A TE 20 and in 1952 the TO30. We never had a problem with the blocks.
If a block cracks the engine either didnt have enuf antifreeze or it got too hot. We never run our tractors hard or at wot. We would run at about 2/3rds throttle.And not overload the engines.
steveormary
