Wagner Loader WF3
mm2007
04-14-2007 10:00:16
I have a WF3 loader on my TO20 and I am in the processes of fixing all leaks.
The cylinders are giving me difficulty. Anyone know how to remove the retaining ring from the insides of the cylinder? I easily removed the packing, but the ring is very difficult. Also does anyone have or know where to find a manual for this loader?
Thanks
Ed H.-Ohio
04-14-2007 18:04:48
 Re: Wagner Loader WF3 in reply to mm2007, 04-14-2007 10:00:16
Hello, I was never able to get that big snap ring out on mine, I dont think they intended it to come back out. If it's a single acting cylinder ( one hydraulic line to it) the packing you removed is all the packing it has, there is none on the end of the ram. If it's leaking out that packing replace it. If the crome is damaged you will probably have to find a replacement -ed
ianb
04-14-2007 17:10:43
Hello,, My loader is on a 1952 TEA 20. I just finished repacking the cylinders on my Wagner loader, not sure what model it is. I had to unscrew the end caps on the cylinders to get access to the clips that control the extension length. The clips popped off easily with a small screwdriver. I used my loader for the first time today,,,it went all the way up but doesn,t want to retract. I,ll try loosening the packing some tomorrow and hope that cures it . Ian
