Rear axles
mm2007
04-27-2007 15:58:19
After a full cleaning and inspection I have determined that a previous owner forgot to install about 0.020" worth of shims. There is some wear marks on the ends of the axles where they were rubbing together. I do not know how long this was allowed to occur but it worked all of the hub bolts loose on both sides.
Because of this: Is there anything that I should check before I finally reassemble the axles into the tractor?
John(UK)
04-28-2007 07:21:50
 Re: Rear axles in reply to mm2007, 04-27-2007 15:58:19
You don't tell us the model of your tractor.
Check the bearings on the Axle-shafts for being rough as they will have been stress loaded, if they are rough you need to change them sooner or later, the diff end will be ok as it floats. Do you know the correct way to set the Axle-pre-load, if you need the information, just email me at:- fergusontractors@tiscali.co.uk
and tell me again what you need and I will send it....John
