How to connect Front Pump for TO-20
Dan Oehmke
04-30-2007 18:59:32
Looking for recommendations to connect the "shreave" (adaptor to connect the pump shaft) to the crankshaft pulley, since my pulley doesn't have the 3 or 4 holes pre-drilled. Can I put the shreave on against the pulley and drill them myself -- using the holes in the shreave as a guide?
Thanks,
Dan
Dan Oehmke
05-01-2007 20:28:46
 Re: How to connect Front Pump for TO-20 in reply to Dan Oehmke, 04-30-2007 18:59:32
Thanks guys for the help. I'll check this out with the local MF and New Holland dealers.
Bruce(OR)
05-01-2007 02:18:28
Your lucky day!!!!
I have a TO-20 that is getting a loader from my 9N I just sold. I have been looking for a pulley for some time now. You can get them for about $55 for a 8/9/2N. Unfortunately your Fergy is gonna set you back $112 give or take. Looks like I'll take a trip into town tomorrow and get the number info for you if your interested? This pulley is suppose to come with the drive pins to accept a flange to spin the pump. We shall see. If this fails to work, I have another plan that should work. However the other plan might be devastating for crankshaft harmonics...
Paul Kingsbury
05-01-2007 06:41:45
 Re: How to connect Front Pump for TO-20 in reply to Bruce(OR), 05-01-2007 02:18:28
Hi Bruce. I live in Bend and was wondering where your at? e-mail me at sweethomewindshield@ yahoo.com and we'll talk. Paul
Dan Oehmke
05-01-2007 03:42:20
Bruce - yes, if info on the right pulley would be great. Thanks, Dan
Bruce(OR)
05-01-2007 09:53:07
 Re: How to connect Front Pump for TO-20 in reply to Dan Oehmke, 05-01-2007 03:42:20
Well, it looks like I have to beat feet this morning and get the loader pulley and parts. I'll be back...
Bruce(OR)
05-01-2007 11:15:43
 Re: How to connect Front Pump for TO-20 in reply to Bruce(OR), 05-01-2007 09:53:07
I went down to the New Holland dealer with the best local parts guy and he located the pulley through Massey Furgeson with a part number of S44982. My cost was $107.14. The ironic part is the Case dealer with the same books was unable to locate the same part... Now he is looking for a flange that will mount to the 2&3/4 inch centers and will accept the 3/4 inch 6 splined shaft to drive the pump flange.
Stay tuned for developments as they happen!!
Bob (Aust)
05-01-2007 13:12:48
 Re: How to connect Front Pump for TO-20 in reply to Bruce(OR), 05-01-2007 11:15:43
I think S.44982 is a Sparex part number, not M-F but that number is not in my TE20 cross reference list and doesn't come up on the UK Sparex site.
Bruce(OR)
05-02-2007 02:15:27
 Re: How to connect Front Pump for TO-20 in reply to Bob (Aust), 05-01-2007 13:12:48
Got out my copy of the sparex catalog from FENA and got to the cross referance in the back under S44982 ad came up with 1750076M1.
Looked on page F3/1 and saw...*!@#$*&!!
I hope this sucker fits! Sparex number S44982 comes up as a Crankshaft Pulley on a TO35 F40. Guess I will look at the 20 pulley tomorrow for shaft diameter comparison.
Good night!
Bruce(OR)
Bruce(OR)
05-02-2007 12:33:30
 Re: How to connect Front Pump for TO-20 in reply to Bruce(OR), 05-02-2007 02:15:27
(Sparex) S44982 pulley hub diameter is the same as the TO-20 hub. The outer pulley is larger in diameter and takes a narrower belt. This attaches to S61559 hub adapter which mounts to the 3/4 inch 6 spline drive shaft to the pump. The price on the Hub adapter is $29.18. The price of the pulley on this site is $43.82. You can now benefit of my experience and save yourself no less than $60.00 in the process.
Good luck!
Bruce(OR)
