mm... Before you go tearing into anything, I recommend you check your spark on that #1 plug to make sure you have a nice fat blue spark. Not a weak orange/yellow spark. But, sounds to me like your #1 piston has a ring problem if it is burning that much oil, that the plugs gunk up every day. See my post below. You may benefit from treating that cylinder with Marvel Mystery oil, some guys also use ATF for the same thing, ie. loosen-up crud that is keeping your piston rings from working correctly. May take several days, several doses of oil, depending on how fast the oil leaks out of the piston. Add oil, let it soak, crank the engine a couple times (with the spark plug out) to work the oil thru the pistons, add more oil, soak some more, repeat steps. Don't be look'in into the spark plug hole when you crank the engine or you may get a face full of oil. Don't crank the engine with oil in the cylinder and the s. plug installed, or risk hydraulic siezing... or worse. Of course, after doing all that, your gonna want to change your crankcase oil. A bunch of M.M. oil in your crankcase is no good. If you decide a ring job, valve job, or rebuild is in your future, actually nearly everything can be done without pulling the engine, and with common hand tools, and a manual. You may find that you don't need a machine shop that is experienced with these engines. George
