govenor anmd carburator linkage
Paul W Olson
05-09-2007 09:04:25
I have taken the linkage off the front end of the tractor where the spring attaches to the accelerator rod and the governor. I need a picture to put it back together correctly.
Does anyone have pictures to help me?
If it would include the carburator linkage that would be great too.
I have a 1952 TO-30.
Thanks
John(UK)
05-09-2007 14:39:27
 Re: Governor anmd carburator linkage in reply to Paul W Olson, 05-09-2007 09:04:25
It isn't just a matter of fitting all back, the linkage for the governor will need resetting or the tractor will not perform well. If you need this information, email me at:-
fergusontractors@tiscali.co.uk
and I will send it and anything else you may need...John
Daniel Collings
05-16-2007 08:46:46
 Re: Governor anmd carburator linkage in reply to John(UK), 05-09-2007 14:39:27
Just curious. What will need adjusting on the linkage? I took mine apart and just bolted it back together and put the spring back on. I didn't see any adjustments.
email: dcollings@blomand.net
Indiana Jones
05-09-2007 12:27:33
 Re: govenor anmd carburator linkage in reply to Paul W Olson, 05-09-2007 09:04:25
Paul, I had to buy a replacement governor compensating spring (mine was missing). If yours is an original, let me know how tough it was to hook it back up. My replacement seems MIGHTY stiff. I don't know if it's supposed to be that way or not. I'm hoping I didn't get the wrong spring. Seems like when installed that it would pull against the throttle rod so much that the friction disk wouldn't be able to hold the throttle steady. I've already adjusted the throttle linkage as tight as I could to the friction disk because it was slipping before I took it apart.
ddfitch
05-10-2007 04:34:26
 Re: govenor anmd carburator linkage in reply to Indiana Jones, 05-09-2007 12:27:33
Mine was missing and I had the same experience as you did with the replacement. Very stiff and had to hook up. I can't find the part number I ordered, not sure but what I got doesn't seem like the right one
dyt4000
05-09-2007 11:17:10
 Re: govenor and carburator linkage in reply to Paul W Olson, 05-09-2007 09:04:25
third party image
