1101404 Delco Remy generator
Josh0103
05-14-2007 08:21:17
Hello, The generator on my 51' TO20 started squeeling and then stop charging. I have purchased a rebuild kit that includes brushes and bearings.Upon inspection, I noticed that the original cloth like insulation that covers the field coil windings is falling apart. I'm thinking that friction tape would be a suitable repair but am unsure. Any advice on a better method would be appreciated.
Thanks,Josh
Bob
05-14-2007 08:42:49
 Re: 1101404 Delco Remy generator in reply to Josh0103, 05-14-2007 08:21:17
Simply spray the windings with electrical insulating varnish.
JohnH-in-MO
05-14-2007 08:29:22
Josh,
Where did you get the rebuild kit? I think I need one too.
Thanks,
John
Josh0103
05-14-2007 19:35:27
 Re: 1101404 Delco Remy generator in reply to JohnH-in-MO, 05-14-2007 08:29:22
John, I found the kit on Ebay. It consists of 3 brushes one bearing and one brass bushing. Good luck. Josh
JohnH-in-MO
05-15-2007 15:11:39
 Re: 1101404 Delco Remy generator in reply to Josh0103, 05-14-2007 19:35:27
Josh,
Thanks for the info. I decided I need to do a little more checking before concluding that my charging problem is the generator. I put a multi meter on it and got zero voltage, but I'm not sure if that's how to test it. I'm going to check all of the wiring and connections to make sure everything is making good contact first.
Thanks again,
John
