TO-35 diesel camshaft
Bobcatnumber1
05-19-2007 22:14:45
I'm installing a new camshaft in my TO-35 Standard Motors diesel. There are 6 bolts that hold the camshaft gear to a hub, and then one big nut (about 1" diameter) that screws onto the camshaft to attach the hub/gear to the camshaft. The first time I overtightened the nut and broke the camshaft. What is the proper torque for that nut?
John(UK)
05-21-2007 08:05:28
 Re: TO-35 diesel camshaft in reply to Bobcatnumber1, 05-19-2007 22:14:45
It doesn't list it in the Service Manual at all. The screws that fasten the chain-wheel to the hub are set pretty low at 18 - 20 lbs ft. As it has a lock-tab to secure it then it should be alright set not too tight. Are you aware of the offset on the chain wheel fixing holes to allow for a "vernier" adjustment on the chain wheel for the valve timing? If you need the information just email me and I will send it:- fergusontractors@tiscali.co.uk
if you do mail just tell me again what it is all about then I won't confuse you with someone else..John
