TE20 Pictures wanted
oddity
05-22-2007 21:18:19
Would anyone have any pictures of what an air cleaner should look like for a TE20 and how it is positioned? Mine has the main air cleaner, but attached to it is a canister funnel looking thing that doesn't look right. My manual doesn't show anything, and it appears I need to get a different one. Any help is appreciated.
Jason
oddity
05-23-2007 06:25:50
 Re: TE20 Pictures wanted in reply to oddity, 05-22-2007 21:18:19
I am certain that is is a TE20 with a continental z120 engine. The dist. is lucas, and I am not certain if the dash was replaced, but I doubt it. The dash does not have the air inlet in it like a TO30.
Jason
Jeff-oh
05-23-2007 10:41:08
 Re: TE20 Pictures wanted in reply to oddity, 05-23-2007 06:25:50
That is fine, you are right the TE-20's did nopt have the dash air inlet. Later TEA's did though. You probally do have a replacement air filter. The originals had 1" x .25" open slots. The TO-20's had 1/8" open screen going into the central tube down to the oil bath.
Jeff-oh
05-23-2007 05:46:58
third party image
There is no other place to get the tractor SN other than the data plate. There are ways to estimate the age, by engine SN, casting codes etc.
As for the air cleaner, you may or may not have the original to the tractor.
First, we must determine what tractor you really have. Do you have a TE-20 or a TEA-20? Use the provided picture to help determine the type of engine. i.e. where is the oil fill. If at front you have a Continental engine (TE-20) if at rear you have a Standard motor (TEA-20).
The later TEA’s had a dash screen air inlet which this hose you describe hooked up to. I am thinking that you may have an original air filter but a replacement dash, which could explain the missing tag. If you later model year tractor receive the dash from an earlier year tractor or even a different model (i.e. TO-20) then the tag would have been removed to eliminate confusion.
Even if it is a replacement air filter, it should not matter much as the only difference was where the air was taken. However you may want to fashion a screen over the opening.
Another possibility is that you have part of a pre-cleaner assembly.
Jeff
oddity
05-22-2007 21:21:44
Also, my data plate near the steering wheel is missing. Where would I find the serial number for the tractor other than this? Jason
John(UK)
05-23-2007 10:44:38
 Re: TE20 Pictures wanted in reply to oddity, 05-22-2007 21:21:44
Without the serial plate there is no way of finding out the serial number.
oddity
05-28-2007 20:34:10
 Re: TE20 Pictures wanted in reply to John(UK), 05-23-2007 10:44:38
Thanks for the replies. I am learning.
Jason
John(UK)
05-29-2007 08:51:39
 Re: TE20 Pictures wanted in reply to oddity, 05-28-2007 20:34:10
Unless you ask you will never learn, so do not be afraid of asking.....John
