Full time pto
DavePA
02-03-2001 13:39:44
to-30 with a front end loader which is plumbed by way of the rear main pump. Is there any way to upgrade hydrolics to make live so that pto shaft is not always engaged while using loader? Have a leak some where in the rear lift assembly as it will no longer raise a load. Just was hoping to kill two birds with one stone when making repair to rear.. thanks DavePA
Ray,IN
02-03-2001 20:40:39
 Re: full time pto in reply to DavePA, 02-03-2001 13:39:44
No, it would'nt work. The PTO shaft extends thru the hyd. pump into the transmission. The PTO shaft therefore powers the hydraulics. Look at past posts on adding a pump to the front of the motor. I have seen such discussions on this and other boards.
