gotter' done
minnesotabuck
06-19-2007 14:05:12
My fergie to-20 is finally up and running. The guy I bought it from had it tore down to restore and it had been sitting for 12 years in pieces. We replaced any leaking seals and gaskets, all new wiring, rebuilt the 6 volt generator, new carb kit,new gauges, new pto seals, new tires on rear, new battery. After cleaning and priming the metal we put her back together and boom we have ignition. These are sweet running little tractors. The one thing I missed was a crack in the exaust side of the manifold. Well that is going to have to wait to be repaired until winter because I can't stop takin' her for a spin. This winter I am going to tear the sheet metal off and get new, triing to bring her back to as close to perfect as I can.
John Mason, Michigan
06-19-2007 14:22:49
 Re: gotter' done in reply to minnesotabuck, 06-19-2007 14:05:12
Got any pictures? Any relation to colorado buck? I have a TO35 that was in storage for 10 years, had not run in 3. Took my time and went through it. Same result as you had. Started right up. I also have a crack in the exhaust manifold. Someone had welded a support bracket from the radius rod to the muffler, which in turn cracked the manifold. I also need to remove it and get it welded. Sincerely, John.
