'54 TEA Starter continuity
chuck130
06-20-2007 04:24:42
12V generator, positive ground - while troubleshooting why I cannot get my machine to run, (it had 1.4 hrs on it before it quit) I probed and found continuity between the starter terminal (-) and the chassis (+). Could this be the source of my electrical woes? (I am confident that it's not fuel related and have checked all other aspects of the electrical system).
Phil (NJ,Az,Sask)
06-24-2007 19:44:34
 Re: '54 TEA Starter continuity in reply to chuck130, 06-20-2007 04:24:42
chuck130,
I don't know what you mean when you say continuity. If you are measuring OHMs you need to remember that -ve battery exists on some points, like the little S terminal on Starter solenoid. Ohms & battery don't mix!
The Starter is a very low impedance LOAD and will have continuity between its frame and the big stud connected to the solenoid.
Hope this Helps,
DennisPinOhio
06-20-2007 05:34:30
Jerry/MT will surely answer this for you as he is an elecrical whiz.
chuck130
06-20-2007 09:47:36
 Re: '54 TEA Starter continuity in reply to DennisPinOhio, 06-20-2007 05:34:30
Further to my last, because there is continuity between the starter terminal (-) and the chassis (+), there is also continuity between the two terminals of the transmission-mounted starter switch. This doesn't seem right to me - shouldn't there only be continuity when the switch is closed (gear shifter to 'S')?
Jim W
06-20-2007 11:48:00
 Re: '54 TEA Starter continuity in reply to chuck130, 06-20-2007 09:47:36
Take the wires off the switch and measure again, and there should not be continuity unless the gear lever is in the start position.
