TO-20 Runs and Stalls
n986t@yahoo.com
06-24-2007 18:58:29
OK- I know this is a common issue. SOMEONE must have figured it out by now. I've read all the posts here and have confirmed all the trite fixes ("cow-peeing-on-a-flat-rock" fuel flow and the "bluish-white-spark" ignition).
Here's the deal: Was given a '51 TO-20 that sat unused for maybe 2-3 years. Replaced the coil, rebuilt the distributor, replaced the fuel line and filter (routed away from the manifold to prevent vapor lock), rebuilt and thoroughly cleaned the carb (8-10 times now), replaced the entire coolant system, flushed the tank, replaced the sediment gasket and filter, etc., etc. Tractor starts effortlessly and idles smoothly, with excellent throttle response in all ranges. No misses, no backfires, just hums right along.
Once I start driving around, it runs perfectly for just a couple minutes and then cuts out. Will sometimes re-start and run for another minute or so before eventually dying completely. Have checked (and rechecked) fuel flows and it's good all the way through. Am definitely getting good spark as evidenced by the smooth running on all cylinders.
I'm at my wits end with this thing. Would greatly appreciate any insights. As often as this problem is listed here, surely someone has figured it out by now.
Anyone?
N986T@YAHOO.COM
06-27-2007 11:34:19
 Re: TO-20 Runs and Stalls in reply to n986t@yahoo.com, 06-24-2007 18:58:29
SUCCESS!!!
Turns out it was either the ignition switch (which looked pretty damned ratty when I pulled it) or the coil (which was not the right one for this tractor). Replaced both this morning and she fired right up and ran like a champ. Finally....
Can thank you all enough for your help.
N986T@YAHOO.COM
06-26-2007 03:00:49
You guys are great- many more specific solutions being offered here than I've seen in past posts.
I picked up a new coil (NAPA IC-14SB; had to send the knucklehead at the counter back twice when he brought me the wrong ones even after I gave him the part number on a piece of paper) and a new 20a switch yesterday. Will try those solutions tomorrow. Also suspect of the aforementioned connection between the coil and the distributor; as I recall it is probably the original cloth-covered wire from the 50's. Will replace it as well.
Thanks again for all the assistance. I'll keep you all posted.
Phil(NJ,Az,SasK)
06-25-2007 22:45:04
third party image
This is a Ford 8N "Side mount" Flow chart but it should work on your Tractor.
Voltage Measurements are in upper left
I would guess that the small WIRE from Coil to Points is shorting where it enters the side of the Distributor. Shake the sucker!
Hope This Helps
mark from the fort
06-25-2007 22:10:40
My money is on an electrical problem.
Two thoughts that were not mentioned, but a stretch. I had a pin-hole one time on a float on a carburator. It would float/function fine to start with but would gradually fill up and no longer stop fuel flow.
A better possibility is that if your tractor sat for a while--the sediment bulb in the bottom of the gas tank has two (at least on my 35's they do) have two metal tubes which stick up into the tank and allow gas to flow down into bulb, then carb. I have had several fill full of dirt, rust, varnish. At start-up and idle, enough gas was making it through---however, when working or giving it throttle, it would sputter and die due to not enough gas making it through. After she would sit a while, she would start again. I must have checked every part of ignition and carb a dozen times. Might be worth a look. HInt. try to wait until tank is empty, or close, as a lot more gas gushes out of tank that it seems is in there. I use a 2' piece of downspout, a funnel, and a 5 gallon bucket.--and yes, I have overfilled a 5 gallon bucket thinking the tank was "almost" empty.
Good luck, Mark
CENTAUR
06-25-2007 13:22:35
Read my post under 9n-2n -8n.An unlubed cam will wear off the rubbing block in no time.CENTAUR
Gene Stevens
06-25-2007 03:23:20
Could be the gas cap. Try removing it the next time.
Jerry/MT
06-24-2007 21:27:36
I'll try not to be trite!
If I were you when the problem occured, I would immediately check the SPARK AND THE FUEL DELIVERY. That would give you a starting point.
My gut feel is that you are having an ignition problem BUT I NEVER ASSUME ANYTHING IF I DON'T HAVE TO! You could have the vent plugging in the fuel cap which allows fuel delivery for awhile and then restricts it. So check the vent in the gas cap.
You didn't say what electrical system you have (6V OEM or 12V conversion). There are usually two things that cause the problem you are seing. One, as Phil has pointed out is a bad ignition switch which get a high resitance in about 10-15 minutes or an overheated coil which usually takes much longer to overheat.
The former can be checked by putting a jumper across the switch and seeing if that improves the situation. If it does, replace the ignition switch.
IF you have a 12 V electrical system, make sure that you have a real 12V coil, not the 12 V coil that has the tiny writing on it that says it must be used with an external resistor. If you have one of those and you didn't put the required resistor in series with it, you could be overheating the coil. Or if you have a 6 v coil on a 12 V sytem, the same is true. If you have acoil AND the resistor, when this occurs check the continuity across the resistor and see if it's failing in that mode.
Finally don't conclude from smooth running, that you must have a good spark. Check it out! It takes less than 2 minutes and it's gotta' be FAT, AND BLUISH-WHITE!
phil(va)
06-24-2007 20:40:53
Wild guess, usually this will just make it run with less power but will still run, but is it possible you may have the distributor / coil wires backward, i.e., positive and negative switched? If tractor is positive ground, positive on coil should go to distributor (ground). Vice versa if negative ground. Another thought is to jump around ignition switch, which may go bad when hot. Another thought is replace condensor (again). New ones can be bad. Another thought is replace coil (again). New ones can be bad. Hope that helps.
Chuck (CA)
06-24-2007 20:47:56
 Re: TO-20 Runs and Stalls in reply to phil(va), 06-24-2007 20:40:53
Yep, I would first try another coil.
Landon
06-24-2007 19:16:25
Sounds like it could be electrical problem. You say drive around and it dies. Maybe something is grounding out and acting like "kill" switch. Seems like you R/R everything else. Good luck
Gerald J.
06-24-2007 21:12:01
 Re: TO-20 Runs and Stalls in reply to Landon, 06-24-2007 19:16:25
Like the wire to the points with squeezed insulation or the insulation scraped off.
When it idles and won't run long under load that still sounds a lot like a fuel flow problem because a coil heating up should heat the same at slow or high speed so it should have troubles at about the same time whether idling or running hard. A condenser may fail faster running fast, but my condensers usually don't recover from a failure.
You might check for fuel level by screwing in a hose barb fitting in place of the float bowl drain plug and then run a piece of clear plastic tubing to the side and up so you can have a gas level guage and see if its holding up when running hard.
Gerald J.
DennisPinOhio
06-25-2007 05:47:35
 Re: TO-20 Runs and Stalls in reply to Gerald J., 06-24-2007 21:12:01
If you do make a "sight gauge" as suggested, be sure to buy a gasoline resistant type of tubing, such as TygonŽ.
N986T@yahoo.com
06-25-2007 05:10:33
Many thanks for the replies- you've given me two new things to try. I'm admittedly a novice when it comes to old tractors and sincerely appreciate the assistance.
First the coil. Can someone please provide a part number for the appropriate coil? I'll pick one up and try that as a solution. Not certain of the coil as it was given to me as NOS parts with the tractor. Could be bad.
As for the ignition switch, there's no keyed switch on the tractor; just a toggle switch that completes the electrical circuit. Definitely could be the culprit as it too was a NOS gimme. What are the appropriate specs on the switch I need. I'll replace it as well and see what I get.
Again- many thanks to all. What an excellent resource this board is.
DennisPinOhio
06-25-2007 14:50:07
 Re: TO-20 Runs and Stalls in reply to N986T@yahoo.com, 06-25-2007 05:10:33
Coil part number is IC-14SB at NAPA.
Gerald J.
06-25-2007 09:25:46
Go to NAPA and ask for a 12 volt coil that needs no resistor. I don't know their part number but its a generic part. I think a Ford truck coil, say from 1965 would be right but it must be labeled 12 volts and not labeled needing resistor.
The ignition switch needs to carry 8 or 10 amps, 15 or 20 if the lights are on it too.
A universal keyed ignition switch will carry the current and isn't expensive. Nor will it last forever. Mine failed just like your symptoms, a new switch and tightened up wiring connections cured most all those problems. I still need to clean up the connections at the transmission safety switch.
Gerald J.
