TO30 Lost Spark
Baronvonstueben
07-10-2007 12:37:03
I have had my HF TO30 for about 7 months. The old girl has started well even at 20 below zero. Recently I used the loader for a few hot and humid days for concrete work. The tractor began to take a few cranks to start later in the day and I didn't think much of it but now it won't start.
Battery is strong. Gas flow is good to and from the carb. No spark. This was a 12 volt conversion. The high tension cables are all good. New spark plugs. The starter motor turns over strong. I noticed the coil is still the original 6-volt. How do I test the coil to see if this is the culprit? Other suggestions? I am an amateur so hope I have provided enough info.
Jerry/MT
07-10-2007 21:38:40
 Re: TO30 Lost Spark in reply to Baronvonstueben, 07-10-2007 12:37:03
If you are running a 6 volt coil on a 12V system your lucky you just now had the problem. The current the coil has about doubled and that usually causes the insulating tar to melt after about an hours running time and then the engine stops. In about an hour,it will restart, run for an hour and that stop again. The other problem is that the higher current burns the points. My advice is to get a new, genuine 12 V coil (NAPA IC-14SB ~ $15)and install that. Also pick up a new set of points and install those and set the gap. You should be good to go.
The only test you can do is for continuity on the primary winding but if it's a 6 V coil, and you have a 12V system, you need a 12 volt coil or the appropriate resistor to make a "half breed" system to use a 6V coil.
Baronvonstueben
07-11-2007 15:52:57
 Re: TO30 Lost Spark in reply to Jerry/MT, 07-10-2007 21:38:40
Many Thanks Jerry. I picked up a new coil and will try when the rain stops!
Jerry/MT
07-11-2007 16:55:37
 Re: TO30 Lost Spark in reply to Baronvonstueben, 07-11-2007 15:52:57
Check your points out, too. They are mostlikely burned or pitted.
baronvonstueben
07-14-2007 21:03:45
 Re: TO30 Lost Spark in reply to Jerry/MT, 07-11-2007 16:55:37
I changed the coil and points. The points where pitted as you stated. The old girl coughed a few times and started right up!
