Dimensuins for a box
Frank Biscardi
02-09-2001 17:09:02
Folks,
I bought a "lift-all" today. It is the steel frame and 3 point connector that you can build a sort of box for the Ferguson. I want to carry construction material, cordwood etc. What do you all think is the optimal size for the box?
Thanks
Frank
Duner Wi
02-10-2001 08:16:30
 Re: dimensuins for a box in reply to Frank Biscardi, 02-09-2001 17:09:02
270 gallon fuel oil tank sawed apart is what I like. If load is heavy swivel dolly wheel or wheels at the back will help keep the tractor front end on ground.
Frank Biscardi
02-10-2001 17:56:43
 Re: Re: dimensuins for a box in reply to Duner Wi, 02-10-2001 08:16:30
Dolly wheel! Wow, that is a great idea. I think I have one laying around somewhere.
Thanks
Frank
Frank Biscardi
02-10-2001 17:56:25
Thanks
Frank
Ray,In
02-09-2001 20:46:18
Mine is no wider than the rear tires, so hauling through the woods is easy. The length f/r is 30" long enough to carry firewood, but not too long,do'nt want to raise the front end going uphill. The sideboards are 24"lift outs. So you see, the deminsions depend on your tractor and your terrain, and uses.
