Sure seals
Nifter
08-04-2007 06:14:20
Has anyone had experiance with the "sure seal" rear wheel seals on a TO-20? Seems like an easy fix, however, in my experiance easier isn't always better. (or even equivalent) I only want to do this once.
Thanks.
Nifter (va)
08-07-2007 14:37:24
 Re: Sure seals in reply to Nifter, 08-04-2007 06:14:20
Great site George. I think I'll give these things a try.
paul in Ms
08-06-2007 03:16:04
I installed sureseals on my To-20 5 years ago. Have work great. You should repack the bearing every 1000 hours or so. Which means you will need to replace the sureseals with new ones but they are cheap. I replaced the factory seals twice . They would not last 6 months before they would start to leak.
Doug A
08-05-2007 09:28:14
for what it worth, I stumbled into a website that describes installing sure seals along with some good photos Link
may>Link be a winter projet for my to-20
Doug
gshadel
08-06-2007 12:28:56
 Re: Sure seals in reply to Doug A, 08-05-2007 09:28:14
That's my web site, I like seeing other people referencing it as a resource... that's why I made it! Thanks Doug!
Sure seals are a solid repair job for old, leaky TO-20 axle seals. It is easy compared to replacing the original axle seal, and it is a long lasting fix if done correctly. I don't agree with the need to re-pack the bearing every so many years.... unless your driving your TO through high water. Just pack the bearingt good with grease (best you can) before installing the sure seal.
George
Andy D.
08-04-2007 08:20:01
I have a TE 20 with the same issue. Do the sure seals fit it? Is it a good, long lasting repair? Is there some reason the left axle seal fails more often than the right?
Bruce(or)
08-05-2007 00:44:11
 Re: Sure seals in reply to Andy D., 08-04-2007 08:20:01
I did Sure seals on a 9N that I had for a short while. Pack the bearings with grease as best as possible prior to seal installation. I drove mine in with a 3" long PVC pipe the same diameter as the seal. I also ran permatex #2 around the outer edge prior to installation and they went in with no problem. I currently have a TO20 that is going to get the same treatment soon enough.
