1954 Ferguson TO-30 weight
technoid
08-16-2007 18:55:43
What is the weight of this machine? No attachments and no fluid in the tires.
hamx15
08-19-2007 03:59:09
 Re: 1954 Ferguson TO-30 weight in reply to technoid, 08-16-2007 18:55:43
well..... .don't disreguard the fact that,you may (depending on the size)already had 1000 lbs,on the axels,just from the trailer weight.....If the trailer you said specifies 4000 lbs,it probably is a single axel trailer....in which case your depending on each tire being able to carry 2000 lbs.....Alot of times,trailers are sold rated,by the axel/s used,but the tires on the trailer do not match that standard.If you've got 4 ply tires on there,I don't think they'll be good for 2000 lbs.
Just a thought ..... .
Phil Fenner
08-17-2007 13:14:42
The owners manual says the weight is 2570 lbs with fuel and lights.
Phil(WA)
technoid
08-17-2007 15:44:14
 Re: 1954 Ferguson TO-30 weight in reply to Phil Fenner, 08-17-2007 13:14:42
Thank you. That was a big help! The trailer I am using is rated to carry 4,000 Lbs.
Irv ( Ia)
08-16-2007 18:59:59
My TO-20 weighs about 2600# - 2700#. It should be about the same.
