TO-35 trans. gears
Bob R
09-10-2007 18:41:34
My MHF TO-35 needs a new reverse gear.Serial # on dash plate is 167781. # on side of transmission is 182-840-MI.
The gear in my tractor is a 17 and 21 tooth, but the only gear i have found at Online Parts Dealer is a 13 and 21 tooth for TO-35 tractors with serial # 17159 and higher and 8 speed trans.
my TO-35 is a 3 speed with high-low range and live hyd. power.
Can anyone advise me on how to obtain the right gear for my TO-35??
John (UK)
09-12-2007 06:25:00
 Re: TO-35 trans. gears in reply to Bob R, 09-10-2007 18:41:34
The gear you need is part number 180-424M1 this was used on tractors up to serial number 171549.
If you can't find one of these then it would be possible to convert the Transmission to the later type, all the parts for that are available. Your Transmission is classed as a SIX speed. If you need more info on this just email me..John
Bob R- Minnesota
09-15-2007 08:41:33
 Re: TO-35 trans. gears in reply to John (UK), 09-12-2007 06:25:00
John (UK),
Thanks for the excellent idea. I will check a parts dealer for availability. I will keep you posted on my progress. Thanks again!
Bob R.
John (UK)
09-16-2007 04:57:37
 Re: TO-35 trans. gears in reply to Bob R- Minnesota, 09-15-2007 08:41:33
I don't know if these parts are still available from MF or not but they are listed in the Sparex list, I can send you that if it is any use to you so you can order from them....John
