Ferguson identyfication.
Mick Smith
02-18-2001 07:32:18
WHERE CAN I FIND THE IDENTYFICATION nOS / PLATES ON MY T20.I`VE FOUND THE ENGINE No.
THANKS MICK.
Ray,IN
02-18-2001 16:59:50
 Re: Ferguson identyfication. in reply to Mick Smith, 02-18-2001 07:32:18
There is a post on here or the Massy board that said to take the nos. from the engine,diff.,tranny to a MF dealer. They could look up your tractor type & yr., but not the serial #. If there is not an id plate above the steering wheel your s# is gone. Assuming you do have a TO20/TO30,all were located there.
jon
02-18-2001 14:12:10
As far as i know the only ID plates are the serial no plate mounted on the flat part on top of the dash board immediately forward of the top of the steering column, - if yours hasn`t corroded away. apart from that the only other no. is stamped on a the engine behind the ignition coil bracket (Later TE 20 engines), all others are casting nos.
