starter question
becheck
09-14-2007 15:04:20
Does anyone know if I can buy a starter at the local parts store that will fit a 1950's model to 35
with a 4 cylinder gas engine? They seem to look like a common starter.
Thanks, mike
Bob (Aust)
09-16-2007 15:40:52
 Re: starter question in reply to becheck, 09-14-2007 15:04:20
This site:
"Starter , 12 Volt - For TO20, TO30, TO35, F40, MH50, 50, 65, Early 302, 304, 356. Starter assembly for 6 or 12 volt systems with Continental Gas engine. Has 9 tooth gear on bendix."
Part No: 4858MFGXL $159.90
Think you will find it cheaper to overhaul.
phil(va)
09-15-2007 07:21:51
Do you have the bad starter? If you do, take it to an automotive electrical repair shop and they can rebuild it. They can get all the necessary parts for these starters. It is usually much less expensive than buying a starter.
molinebob
09-14-2007 15:45:25
You sholud be able to, I know my local NAPA can get almost anything for any tractor.
