TO-20 Oil Filter Install - Port welded shut
~Paul
09-19-2007 07:57:55
Fergie has filter port welded shut. Dropped pan, and found only the wire mesh screen, and the (I assume) filter tube hole JB-welded shut, the end open. What appears to be a wire spring is,
I assume, to hold the filter down against the filter port/oil pan. Daunting reassembly, it would seem.
Should I Drill hole back and close end of tube?
Does the mesh screen mount on the other tube?
(Doesn't seem like there is room for both, as tubes are close together.) What of the spring?
Any comments as to how to proceed would be greatly appreciated, as my significant other is breathing fire to get the back mowed, and it is dangerously dry .
Have ordered a manual, but it is taking awhile for delivery, and the noise is increasing.
Thanks, ~Paul
Dan S (NY)
09-19-2007 09:41:21
 Re: TO-20 Oil Filter Install - Port welded shut in reply to ~Paul, 09-19-2007 07:57:55
third party image
Here is a page from the parts book.
My oil filter plate is also welded shut. It was kind of tricky getting everything in place and getting the pan on! I haven’t opened it up for several years now because its such a pain. The tube that goes straight up into the center crankshaft bearing cap is what delivers oil to the filter. There should be a very small hole in the side of this pipe that the oil comes out. Don’t enlarge this hole because it could drop your oil pressure. The bottom of this pipe is where the bolt would go to hold the oil filter plate on if it wasn’t welded. So to install, slide the spring up the oil filter pipe against the bearing cap. Next there is a can with two holes in the top for the two pipes (the oil pump suction and oil filter return lines) to come down through. Then the screen goes in the can, then the filter slides on, then you put the plate on the bottom and install the bolt. The spring pushes the can and screen down against the bottom of the oil pan. Getting all of this together with the bottom welded shut will the tricky part. These engines only filter a small amount of the oil so the filter is not as critical as a full flow system so if this is not a heavily used tractor, you could just leave the filter out and change the oil more often.
Dan
