gshadel
10-02-2007 08:31:59
Re: How do I check generator? in reply to Gene in La, 10-01-2007 22:38:53
this kind-of builds on the other guys replies. Your generator & voltage regulator are wired together, the regulator controls the gen. output. If the regulator is acting-up, your generator output will be zero. If you check the volts across the battery with engine running & engine off, and conclude your generator is not charging. You still need to decide if you have a generator problem, or a regulator problem. The easiest way to do that is to run your engine at working speed (not idle), take a piece of wire and connect the (F)field terminal on the generator, to a good ground, like the ground lug on the back of the dash, or the pos. terminal on the battery. Make sure your ground lug in clean & shiny. When you jumper the generator like that, it FORCES your generator to it's full output, which is ~7.2V or so. You should see that voltage across your battery. If you don't see the voltage increase when you jumper the generator to ground, you either have a bad wiring connection from the generator armature (A) terminal, or the generator is bad. If that test does give you the desired volts, then take a look at your regulator. A common cause for regulator problems is a corroded ground on the regulator. One of the mounting bolts acts as the gound, if corroded... no charging. All this assumes a few basic assumtions with your stock 6V TO-20 system - positive ground, 6V battery, clean & shiny terminal connections (6V is very suseptible to corrosion), and that your generator has been polarized. All those things need to be in place first before tearing into the generator & regulator. The generator is typically very easy, and inexpensive to fix if you find it is not charging. George
