ferguson jack
Ben Zelasko
10-15-2007 17:04:00
I have located a piece which my gpa says is a factory stand for a ferguson tractor. It has the factory tag on it and is supposed to be put under the front axle and then drive forward. Has anyone ever heard of these?
oldgit
11-27-2007 19:58:53
 Re: ferguson jack in reply to Ben Zelasko, 10-15-2007 17:04:00
If you could post the dimensions it would be great I wouldnt mind trying to build one. it would probably be safer than the way I lift mine now.
Oldgit
Willy/30-OD
10-16-2007 03:04:10
I'm not real familiar with the use of the jack and only have the back piece for mine. I'm wondering if they where made for field use or would you feel ok with lifting your tractor on a concrete floor.
Jeff-oh
10-16-2007 06:10:55
 Re: ferguson jack in reply to Willy/30-OD, 10-16-2007 03:04:10
There were two types made. One has a chain like the one pictured and it could be used on a floor. The other had spikes on the front piece, thus not good for a concrete floor.
Tioga
10-15-2007 19:22:33
Actual jack in use.
Tioga
10-15-2007 19:24:52
 Re: ferguson jack in reply to Tioga, 10-15-2007 19:22:33
Tractor Jack 2
Tioga
10-15-2007 19:17:03
Here you can see what the jack looks like in use.
Tioga
10-15-2007 17:13:03
Yes. I have one. It sounds like you only have a part of the stand. there is also a larger section that attaches to your 3pt hitch and then the tractor's hydraulics raise it.
Willy/30-OD
10-15-2007 17:08:05
IF you go to the FENA website there are pics of one in use at the Albert City show.I have the back half and haven't made a front piece yet.
Tioga
10-15-2007 17:14:18
 Re: ferguson jack in reply to Willy/30-OD, 10-15-2007 17:08:05
I have the whole jack if either of you need dimensions to make the other.
